Solved by MarkPendergraft. Go to Solution.
Toolspace->Settings->Right click root (drawing name) and select "Edit Drawing Settings"
Go to the Ambient Settings tab, here you will find the controlling settings for all civil objects and reports.
Under Angle, make sure you are set to Degree, Precision is set to 4, and Format is set to DD°MM'SS.SS"
Do the same for Direction
Under Area, set your units and precision accordingly
Under Distance set your units and precision accordingly.
When you have some time you should go through all these settings in your template drawing and make sure they reflect what you would like to see.
-Mark P.
