Right on, I'll check it out!
Thanks for your suggestion Nick!
wrote in message news:5258035@discussion.autodesk.com...
Hi Rich,
If you go to the autodesk support pages there is a utility to convert
landdesktop points into civil 3d points. You can then work with them.
Nick
"Rich Banker" wrote in message
news:5258002@discussion.autodesk.com...
Hi Melanie,
Thanks for your reply! Unfortunately all I have is the .dwg file. I tried
"Import From Land Desktop" without any luck. The points are proxy
graphics... Does that matter?
Rich
wrote in message news:5257994@discussion.autodesk.com...
After you open the file that was created in LDT you may want to first go to
the General Pull-down menu and select Import Data From Land Desktop. Do you
have just the drawing for LDT or the whole project. Hopefully you have the
whole project because the points are stored in an external database.
If you are able to get the points from the LDT project you can then
right-click on Surfaces under your Prospector tab, and select New. After you
create your new surface, expand it, expand the definition tab and right
click on Point Groups to add in your data.
Let me know if that works!
-Melanie Santer
L.A. CAD
