Hi
I am trying to added station labelling to sample lines (similar to how u can add stations major minor to alignments)
is there a way?
I though of creating dynamic block and inserting over the top of sample line but the text has to be manually entered or edited.
please help soon.
Solved by jmayo-EE. Go to Solution.
Solved by tcorey. Go to Solution.
The Sample Line Label Style will allow you to add Raw Station Value as a label component.
i am trying to add values like 10, 20, 30, .. and -10, -20, -30... so it corelates with the section view.
Yes. Offsets. I was gonna ask you if that's what you meant, but the other answer was so easy.
Sorry, without customizing (.NET programming) you're not going to get this to work as a Sample Line Label. You will need to find a workaround, like offset the alignment through each of the offsets, and then create a path array along each pline, using a piece of text or block with attribute. It would be easy with VisualLISP to customize this.
can u explain (in basic terms) how to do this with lisp or any other method?
i dont quite get what u mena by offseting the alignment , couple key points -
sample line are not equally stationed, some sample line are longer than others.
