Civil 3D Forum
Labels in Quick Properties
2 REPLIES 2
320 Views, 2 Replies
Should Civil 3D labels be able to show up in Quick Properties?  Currently mine do not and I can't see a option to add them in the Quick Properties customization.  Mostly I'd like to be able to change the label style from Quick Properties rather than the full Properties box.
2 REPLIES 2
AlmasSuljevic
In Quick Properties panel you may click slightly below X to get into Customize dialog. There you can chose what elements you want to display in quick properties.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
in reply to: AlmasSuljevic
Almas.  Thanks for your response.  I can customize quick properties to include all the Civil 3D objects.  The issue is that I can't get civil 3d labels to appear in quick properties.  I want to be able to select civil 3d labels and change thier style etc from quick properties.  Is that simply not possible or am I just not seeing it?
Rail Community
