Does anyone know how I can label my alignment widening? A label at the start and end of the widening, like the image below
This was asked 2 years ago and support did not know a Civil built-in solution.
The Suggestion was to use AutoCAD dimension instead.
Of course, you can use Station labeling
Command: AddAlignOffLbl
But will not update immediately if the widening offset is changed.
What are you trying to get?
Your Name
Please show me where that is indicated 😂
Your Name
Thanks for the replies. I was wanting alignment labels that use the data from the Widening Region group in the image below.
Paul
I think what you want is easy to setup, but may need a more complete mental picture. Can you make us a drawing using plain text & lines to show what data you want and how you want it arranged?
Geometry labels at PIs with reference text components (to the parent alignment and profile or surface) for offsets and elevations. Lengths can be shown in segment labels.
I was hoping I could define a alignment labels style that uses "widening group" data. one label would be "begin transition sta xx+xx", the next label would "begin widening sta xx+xx", the next label "end widening sta xx+xx",
the lest label "end transistion sta xx+xx". Right now I an just using a sta/off label style.
