We recently started using Civil3d 2013. We made a huge jump from LDD 2008. We have profiles designed and data short cuts are created. We have existing and proposed.
Now i've created a reference and brought them into another drawing. First I tried to set up the color and linetype for each profile. When I do this. Both the exising and proposed become the same color and linetype.I do not see how to select the existing from the proposed and set the color and linetype.
Next I select the proposed profile and right click and select Edit Labels. I start to create the PVI labels. When I do this the PVI's for the existing profile get labeled. I want the proposed profile labeled. Not the existing.
Any input would be great
I tried that and they both change.
I think this problem has something to do with the data shortcut.
Please look below, We have both the existing and proposed profiles under the same data shortcut. Is that correct? or should they be seperate?
Thank for the input
Please look below, We have both the existing and proposed profiles under the same data shortcut. Is that correct? or should they be separate?
As far as the Existing & Proposed profiles under that dref location in your caption that is normal.
For the profile style issue try right clicking on the profile name in Prospector>Alignments>Centerline Alignments>Align Name>Existing Profile Name.
Go to the Information tab & set to desired style for Existing pfl. Repeat this for the Proposed Pfl.
The labeling can be controlled when creating the Profile View pay attention to the "Profile Display Options" step in "Create Profile View" dialog.
Scroll way over to the right of the dialog to the "Labels" column. Set the Existing Profile to _No Labels and set the Proposed profile to Complete Label Set
or whatever your all labels label set might be named.
Now the proposed profile should be labeled and Existing profile shouldn't.
The above assumes you have working profile styles for each profile type and also working label sets to apply to the Proposed Profile.
