Everytime I use the label line command, when I go to plot my drawing I see a box around my label and the label is either chopped off or missing. A rectangle prints out around where the label is. Can someone please help me figure out how to fix this?
-thanks
What kind of plotter are you plotting to? Do you have a background mask set for the labels?
Allen Jessup
Allen Jessup
CAD Manager - Designer
I checked my label style and the background mask is set to false for labeling the bearings. Do you think it has something to do with me exploding the label? Sometimes I explode the label, because the wayit labels the line it is in the way of other objects
Very well could be. I don't explode the labels. What type of labels are you having trouble with.
Allen
Allen Jessup
Sounds like the textmask got screwed up when exploding. Just apply textmask to the text again- usually works.
ok....how do you re-apply text mask to text? I just tested it and it def. happens when I explode the label...I checked my plot preview and after I explode it, I see the rectangular box around label
type textmask at the command line and click the text.
I tried the textmask and I can still see the rectangle. Sometimes I need to explode the labeled text, such as a bearing or distance because the surveyor may need to adjust the distance or bearing by a minimal amount so exploding the label comes in handy for me sometimes. In LDD there was a setting also that you could make the labeling dis-associated, which I also used. Any more ideas would be helpful...thanks...basically I need to know if there is a way after labeling a line, such as a property line with a bearing and distance, to manipulate the label maybe without exploding text?
Rick Jackson
Survey CAD Technician VI
I agree. The OP may want to confirm the settings in the attached.
John Mayo
When you explode a label the first time, it becomes a block. Then when you explode that block, the text mask comes in as a 3d face. you have to delete the 3d face to remove the dark box.
Interesting.
In 2008 & 2011, it became a hatch. But I just tested in 2013, and you're right, it's a 3D face.
But just the other day, I thought I exploded a label in 2013 and it actually became Mtext with a background mask! Answer to years of wishes! Was I just dreaming, or how did that happen?
Mark Green
Working on Civil 3D in Canada
Thanks sooo much!!!!...After exploding text twice and then selecting a window around the text mask to erase and then unselecting the exploded text label is exactly what I was looking for.
