Civil 3D Forum
Labeling Contours
10 REPLIES 10
Message 1 of 11
trynders
2767 Views, 10 Replies
Labeling Contours
Where do I set the contour labeling line to not show or be on layer defpoints. When I click on the label line and right click I can edit the contour label line properties and change the Display contour label line to false but not sure where the style is.
10 REPLIES 10
Message 2 of 11
in reply to: trynders
As you've found you can do this after you label, and you can do more than
one by slecting one then using Select Similar. To keep them form being
displayed when created, go to Toolspace, Settings, right click Surface, Edit
Feature Settings, Contour Labeling defaults, set the Display Contour Label
Line to false.
"trynders" wrote in message news:6334612@discussion.autodesk.com...
> Thanks
Message 3 of 11
If the contour labels are already created, you can turn off the label line by selecting them, opening the Properties box, and turning Display Contour Label Line to false.
Message 4 of 11
trynders
Perfect... Thank You...
Message 5 of 11
klugb
If you want the default turned off:
From settings tab,
Rt-Click "Surface" and select,
Edit Feature Settings,
Expand "Contour Labeling Defaults",
Set "Display Contour Label Line" to False.
Assuming you have a company standard template that is where I would change it.
Bruce
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 6 of 11
JamaL9722060
in reply to: klugb
Hi all,
i adjusted these settings but sound to have no effect on the line! it is still there!
please, have a look on the screenshot below
the file is attached
best
Jamal
Jamal Numan
Message 7 of 11
sjg
in reply to: JamaL9722060
They will not take affect in labels that already exist. They should work in any future labels. With the one that already exists you can select it and go to the autocad properties dialogue, at the top you can edit the visibility
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
Message 8 of 11
JamaL9722060
in reply to: sjg
Now, i got it. many thanks for the help
best
Jamal
Jamal Numan
Message 9 of 11
BrianHailey
I did a blog post on this very topic early in my blogging career: http://civil3dplus.wordpress.com/2010/02/11/those-pesky-contour-label-lines/
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 10 of 11
Sinc
And it doesn't look like anyone else has mentioned it, but AVOID using layer DEFPOINTS for ANYTHING.
You can now specify any layer as being non-plotting, so there's no reason to put things on DEFPOINTS.  Putting things on other layers helps others know what you meant, and is far more useful than simply putting things on a generic layer called DEFPOINTS.  Not to mention, DEFPOINTS is intended to be used internally by AutoCad, and you can end up with "AUDIT$BADLAYER" things when running Audit on drawings if you stick things on Defpoints.
Best rule-of-thumb is to NEVER use DEFPOINTS.  I know this is contrary to what some old-timers used to do, but it's a "best practice" these days.
Sinc
Message 11 of 11
BrianHailey
in reply to: Sinc
And don't use layer 0 either, for the same reason. Plus turning off or freezing layer 0 can have, how shall I say this, some odd results.
GEI Consultants
My Civil 3D Blog
Rail Community
