trynders
Message 1 of 4 (236 Views)
Labeling contours... Is it still true
236 Views, 3 Replies
03-15-2013 06:35 AM
I'm running 2012. Is it still true that I need to label my contours in every drawing? I have a drawing that contains my existing surface (about 90 Acres). I have labeled the contours in that drawing. I then have a output drawing that the existing contours are a data shortcut. The contour labels do not show up. Why?
cbess
Message 2 of 4 (229 Views)
Re: Labeling contours... Is it still true
03-15-2013 06:54 AM in reply to: trynders
Data referencing will not show the labels. You can do an xref or copy your labels from the other drawing, see this thread.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Copy-contour-labels-across-files/m-p/3140152/highligh...
Cory
Civil 3D 2013 SP1
Win 7 x64 SP1
Intel Core2 Duo 2.67 GHz
8 GB RAM
NVIDIA Quadro FX 3500
KMercier_C3D
Message 3 of 4 (190 Views)
03-15-2013 08:54 AM in reply to: trynders
The way our office does it is label the contours in one drawing and also create a data reference of the surface. In all of the other drawings XREF in the 'image' of the labeled contours and data reference the surface, set this data referenced surface to a "No Display" style.
Kati Mercier, P.E.
Co-author of "Mastering AutoCAD Civil 3D 2013"
AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
Valued Mentor
gccdaemon
Message 4 of 4 (183 Views)
03-15-2013 08:59 AM in reply to: KMercier_C3D
You can have both the x-ref and the datalink in the same drawing so why not use both?
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
I7 3820 (3.6ghz quad core with HT)
32gig RAM (Corsair XMS3 4x8g)
Intel x z79 mobo (BOXDX79TO 2011 socket)
Radeon HD 7850 2gb GDDR5
