Data referencing will not show the labels. You can do an xref or copy your labels from the other drawing, see this thread.
The way our office does it is label the contours in one drawing and also create a data reference of the surface. In all of the other drawings XREF in the 'image' of the labeled contours and data reference the surface, set this data referenced surface to a "No Display" style.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
You can have both the x-ref and the datalink in the same drawing so why not use both?
