Civil 3D Forum
Labeling contours... Is it still true
3 REPLIES 3
trynders
401 Views, 3 Replies
I'm running 2012. Is it still true that I need to label my contours in every drawing? I have a drawing that contains my existing surface (about 90 Acres). I have labeled the contours in that drawing. I then have a output drawing that the existing contours are a data shortcut. The contour labels do not show up. Why?
3 REPLIES 3
c.bergthold
in reply to: trynders
Data referencing will not show the labels. You can do an xref or copy your labels from the other drawing, see this thread.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Copy-contour-labels-across-files/m-p/3140152/highligh...
Cory
KMercier_C3D
The way our office does it is label the contours in one drawing and also create a data reference of the surface. In all of the other drawings XREF in the 'image' of the labeled contours and data reference the surface, set this data referenced surface to a "No Display" style.
Kati Mercier, P.E. | LinkedIn | AutoCAD Civil 3D Certified Professional
Pronouns: She/Her
Co-author of "Mastering AutoCAD Civil 3D 2013"
AU2019 Speaker::: CES321590: Analyze and Revise Existing Subassembly Composer PKT Files for AutoCAD Civil 3D
AU2017 Speaker::: CI125544: Analyze and Devise in Subassembly Composer
AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
gccdaemon
in reply to: KMercier_C3D
You can have both the x-ref and the datalink in the same drawing so why not use both?
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Rail Community
