Valued Contributor
4 Kudos
Post 1 of 21
Label Styles and Description key parameters
457 Views, 20 Replies
01-05-2014 11:07 PM
I have been attempting to get my trees looking like this
So from my reading I set my des. key up like this
However this produces one single line of text with the description "span 0 dia. 0.0 Ht. 0" I want them on 3 separate lines, like the above picture.
So I set up a label style
With this component
So does anyone know how I get the  parameters $1 $2 $3 to go in the correct label component?
Look on AU for CV201-5 "Everything You Ever Wanted to Know About Points, But Were Afraid to Ask".
This is a very good document for description keys. The only easy way I know of is to target the Full description and change the maximum width in the labels style otherwise you will need to enter a user defigned property classification.
I would go with the Maximum width and add some spaces between the $# in the description format until you get the desired look.
Distinguished Mentor
101 Kudos
Post 2 of 21
Re: Label Styles and Description key parameters
01-06-2014 02:32 AM in reply to: allywhite666
Your Code from the field collected data would look like this
T 6 2 4
With 2 being your diameter, 4 being the height and 6 being you span/drip line.
Check out the help on description keys it will help.
Note: The code #'s must be separated by spaces.
C3D12-13
Win7x64 6gb
135 Kudos
Post 3 of 21
01-06-2014 04:35 AM in reply to: allywhite666
I don't think you can do what you want to do through description keys. I might be wrong, and it certainly is an interesting challenge. You can do this with User Defined Properties, but it will involve either manually entering in the information point by point, or using the Survey Database.
Dave
Dave Stoll
Mohave Valley, Arizona
Intel Core i7-3820QM 3rd Generation Quad Core 2.7 GHZ CPU
16 GB DDR3 RAM ( 2 DIMM ) / 180 GB SSD
Nvidia GeForce 650M Graphics w/2 GB Memory
Windows 7 Professional 64 bit / AutoCAD Civil 3D 2014/2015
65 Kudos
Post 4 of 21
01-06-2014 04:42 AM in reply to: allywhite666
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
135 Kudos
Post 5 of 21
01-06-2014 05:02 AM in reply to: mikeevans
Mike,
That sounds interesting, but I can't find it. Can you post a link?
Dave
Dave Stoll
65 Kudos
Post 6 of 21
01-06-2014 07:24 AM in reply to: allywhite666
What a shame, it appears anything prior to 2011 has been Archived or removed. What a wealth of knowledge removed.
Maybe Matt Kolberg can help as he chaired the event.
Mike Evans
288 Kudos
Post 7 of 21
01-06-2014 12:08 PM in reply to: allywhite666
Thanks for the accolades Mike. I will try to find my document and post it here. I'm enroute so it won't happen until sometime tomorrow.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
135 Kudos
Post 8 of 21
01-06-2014 01:26 PM in reply to: mathewk
Matt, if you can dig that up, it will be greatly appreciated.
Nosing around, I found Tom Pisani's Webinar, C13081: Pointing out AutoCAD Civil 3D Points. Good, solid information, and in about 36 minutes is a neat idea I didn't know about. Notes--you can tie them to things like points and alignments, and add supplemental information. Might have some application here.
Dave
Dave Stoll
288 Kudos
Post 9 of 21
01-07-2014 05:34 AM in reply to: allywhite666
Here is the document Mike was speaking of.
Matt Kolberg
135 Kudos
Post 10 of 21
01-07-2014 06:37 AM in reply to: mathewk
Excellent! Thanks, Matt!
Coffee is on and I'm going to read.
Dave
Dave Stoll
