Hello. I created profile labels (station & elevation), but I can't seem to figure out how to remove the circular markers. I want to display them in dragged state with leaders and remove the circular markers where the leaders are pointing to.
Thanks.
Solved by Jay_B. Go to Solution.
I misread your post. I'll create a new reply in a few minutes.
Don Ireland
Engineering Design Technician
Without seeing an example, I'm guessing your trying to turn off the circular markers found within the "Profile Style".
Settings Tab of Toolspace > Profile > Profile Styles > Style Name > Edit > Markers Tab > Change any unwanted Marker styles to "None".
Don Ireland
Thanks all!
This might help others also. Although it refers to surface labels as opposed to profile view labels, the process is the same.
http://blogs.rand.com/civil/2013/05/changing-spot-elevation-label-markers.html
I also had trouble removing (x) cross marker from Profile View label Sta/Text...not a Profile label. The marker style is found in Commands.
Toolspace > Settings > Profile View > Commands > AddProfileViewStaElev > Default Style...Marker Style...(x)Cross
Settings Tab of Toolspace > Profile View > Commands > AddProfileViewStaElevbl (double click) > Default Styles > Change Marker style
