Is there a way to label or list a station at a specific elevation? I know how to list and label an elevation at a given station but I need to know where a specific (given) elevation is located on an alignment or profile. I don't care if this is listed or labeled on the alignment or profile, I just need to be able to get a station at a given elevation.
thanks.
It may be possible, but I don't see it directly. As a work around, you can create a temporary surface at the elevation in question add it to the profile view and you will visually see the intersecting point(s) that can be labeled
Your Name
Your Name
Mark Green
Working on Civil 3D in Canada
If you want to do this in plan. You could extract the 3D Chain from the profile [see this thread]. Then draw a polyline at the needed elevation and find the intersection with the chain. You may need to increase the chain tessellation to work in horizontal curves.
Or you can use [this] method to extract a featureline from the alignment and profile.
Allen
Allen Jessup
CAD Manager - Designer
Mark Green
