I'm using "line between 2 points (basically as a quick chord distance). However, I noticed that when labeling items like this you cannot move the text, or rotate the text at all. I know you can flip text and I can change the readability bias, but in some cases the text is just to far from the arc.
I cant use an ARC label because in some cases we have reverse curves/compound curves and are only concerned with the "overall" chord, not the individual curves. Any help on how to get this text a little more flexible would be appreciated.
TIA
Draw a line that doesn't print (by manipulating its color re the ctb file) and label that line.
Mark Green
Working on Civil 3D in Canada
That kinda defeats the purpose of creating a label by using the "line between two points", doesn't it?
So, basically there's no way to manipulate a label when actually using the "line between two points" labeling option? I could have just as easily created a dimension style that shows nothing but the distance.
Thanks for the input people, I guess I'll just create a dimension style for stuff along a curve, I just hate "mixing and matching". I'd rather try to keep it all a "line and curve" label.
I'm having to explode my label by two points so that I can move them. It is ugly but easier than re-labeling when you have to move the xref to a different position. Just make sure you are at the annotation scale you want to use.
Are you saying that you cannot slide the label along the line?
Rick Jackson
Survey CAD Technician VI
