Valued Contributor
PatrickManson
Message 1 of 10 (1,006 Views)
Label Polyline/Feature line with Layer Name
1006 Views, 9 Replies
02-23-2014 01:42 PM
Does anybody know of a way to lebel a polyline or a feature line with its layer name without using mtext and fields/objects.
Basically i would like to be able to add a label, select the polyline/feature line and it will label it with the layer name at appropriate offset and also be orientated along the line.
Thanks for your help, Patrick
Here's a very quickly written lisp to label an objects' layer. No error checking provided, so will fail on non-curve objects (a 'curve' object is a line, arc, polyline, spline, ray, etc.). But the meat of the needed items are here.
(defun c:labelobjlayer(/ LM:objectid model ent obj DIR INSPT MTEXT OFFSET PARM PT TEXT VEC)
;; ObjectID - Lee Mac lee-mac.com & theswamp.org
;; Returns a string containing the ObjectID of a supplied VLA-Object
;; Compatible with 32-bit & 64-bit systems
(defun LM:objectid ( obj )
(eval
(list 'defun 'LM:objectid '( obj )
(if
(and
(wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*")
(vlax-method-applicable-p (vla-get-utility (vla-get-activedocument (vlax-get-acad-object))) 'getobjectidstring)
(list 'vla-getobjectidstring (vla-get-utility (vla-get-activedocument (vlax-get-acad-object))) 'obj ':vlax-false)
'(itoa (vla-get-objectid obj))
(LM:objectid obj)
(setq model (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(while (setq ent (entsel "\nSelect object to label with layer name: "))
(setq obj (vlax-ename->vla-object (car ent))
pt (vlax-curve-getclosestpointto obj (cadr ent))
parm (vlax-curve-getparamatpoint obj pt)
vec (vlax-curve-getfirstderiv obj parm)
dir (angle '(0 0 0) vec)
offset 2.0 ;;adjust to desired offset may want to scale this based on annoscale
inspt (polar pt (+ dir (* pi 0.5)) offset)
(setq text (strcat "%<\\AcObjProp Object(%<\\_ObjId " (LM:objectid obj) ">%).Layer>%"))
(setq mtext (vlax-invoke model 'addmtext inspt 0 text))
(vla-put-rotation mtext dir)
(vla-put-attachmentpoint mtext acbottomcenter)
(princ)
doni49
Message 2 of 10 (969 Views)
Re: Label Polyline/Feature line with Layer Name
02-24-2014 06:50 AM in reply to: PatrickManson
I think the option of a field would probably be the best idea because if you change the assigned layer, the field will update.
But to answer the question as asked, you could probably do what you're looking for with a lisp routine (and if you go that route, you could even include a reactor that will recognize the layer change and update the label accordingly).  This would be a lot more complex than using a field though.
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoCAD 2010/2011/2012
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Customization
Other Helpful links:
My File is too large to post or I can't post it due to privacy issues!
Joe-Bouza
Message 3 of 10 (950 Views)
02-24-2014 12:58 PM in reply to: PatrickManson
What is you adversion to mtext fields for this task? If you cannot use them you will need to find a lisp routine. But as Doni states fields would be the way to go.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Valued Contributor
PatrickManson
Message 4 of 10 (944 Views)
02-24-2014 01:01 PM in reply to: PatrickManson
Thanks for the replies. the main reason for trying to find a better way to label the line without using the fields, is that it is a labourious process to do so. I need to copy the mtext, edit the field, then rotate the text appropriately.
Cheers
Jeff_M
Message 5 of 10 (935 Views)
02-24-2014 01:14 PM in reply to: PatrickManson
Or find/write a lisp routine to automate it....
don.ireland
Message 6 of 10 (934 Views)
02-24-2014 01:26 PM in reply to: Jeff_M
There is a board specifically for Autolisp questions.  You could easily write a routine that will prompt the user for a pline, find out the angle at that location, and place the mtext object with the field in it (at the appropriate angle).  Putting the field in the mtext object will be the most difficult portion of this task and I could figure out how, I just don't have time right now to get into that.
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
Joe-Bouza
Message 7 of 10 (933 Views)
02-24-2014 01:29 PM in reply to: PatrickManson
Thats fair enough reasoning.
perhaps consider a slightly different workflow. Use a dynamic block with a blockplaceholder field for layer, include an alignment parameter and when you insert it will auto align to the line with the correct layer name
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Jeff_M
Message 8 of 10 (910 Views)
02-24-2014 04:12 PM in reply to: PatrickManson
    (eval
            (if
                (and
    (LM:objectid obj)
  (princ)
Valued Contributor
PatrickManson
Message 9 of 10 (901 Views)
02-24-2014 05:55 PM in reply to: Jeff_M
Thanks Jeff, have loaded it - excuse my ignorance, but what command do i use to start the lisp?
Cheers
Valued Contributor
PatrickManson
Message 10 of 10 (899 Views)
02-24-2014 05:57 PM in reply to: PatrickManson
don't worry - like I said ignore my ignorance - I have got it!! works fantastic. cheers
