Active Contributor
eastridge23
Message 1 of 6 (495 Views)
Label Line between two points drag state.
495 Views, 5 Replies
12-21-2012 11:54 AM
Why doesn't the drag state work when adding a line label between 2 points in Civil 3D 2013. Is everyone having this issue?
TRogers
Message 2 of 6 (493 Views)
Re: Label Line between two points drag state.
12-21-2012 12:01 PM in reply to: eastridge23
Unfortunately there is not a dragged state for this option.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
ngs
New Member
ngs
Message 3 of 6 (320 Views)
08-22-2013 03:53 PM in reply to: TRogers
I have just run into this issue and am wondering when this will be available. I am currently using Civil 3D 2014.
Member
ltaylor
Message 4 of 6 (55 Views)
08-27-2014 10:58 AM in reply to: eastridge23
Don't ask me why, but when you label the line (UNDER LABLE TYPE) in the ADD LABELS dialog box you use the "Single Segment" option it will work.  Sadly if you label by the "Line between two points" option it will not work.  I am not sure about the "Multiple Segment" option.  Hope this helps as this is a must have, especially when creating TAG labels.
Employee
peterfunkautodesk
Message 5 of 6 (37 Views)
08-28-2014 07:11 AM in reply to: ltaylor
The drag line seems to be working on my 2015 version of Civil 3D.
Peter Funk
Peter Funk
Employee
peterfunkautodesk
Message 6 of 6 (36 Views)
08-28-2014 07:20 AM in reply to: peterfunkautodesk
My mistake... I was looking at placing the label.
So, the request is for a label between two points that you then drag off the line and just point to dot in space without even the context of the bearing?
Peter Funk
Peter Funk
