Hi Dave,
Can you add to the formatting of the angle display a capability of the label
being the angle only written radially from the intersection at the mid angle
of the intersection. The attached screen grab shows output for two angles
from the lisp program I wrote to do this.
This is the standard method required by the West Australian Titles office.
Laurie Comerford
CADApps
www.cadapps.com.au
"Dave Simeone" wrote in message
news:406488fe$1_3@newsprd01...
> Hi Thomas - Currently there is no direct method to label the angle. I
tried
> the standard AutoCAD angle dimension but it doesn't support the parcel
> object. As a general observation, it may be cleanest if AutoCAD commands
> such as this we able to parcel lines. I'll note it as a requirement. Using
> the current AutoCAD command(s) may be a more flexible and immediate
> solution.
> Note - as a work around (not one that I'm a super fan of), you can explode
> the parcels and use the AutoCAD angular dimension feature.
> Thanks
> DAS
> "Thomas Glidewell" wrote in message
> news:40630390_1@newsprd01...
> > Just wondering if anyone has found a way to label the interior angels
for
> > parcels. If not I would like to have it added to the wish list for civil
> 3d.
> > Our plating department uses this on all our plats and would like to
> continue
> > this with our intergration to civil 3d.
> > Thanks
Attachment not added (content type not allowed): "Angle Label.png"
