Looking for a way to label two station on one alignment in a construction note. See attached.
My only thought so far, not a very good one:
In the picture, the two stations are 29 (I presume feet, but it doesn't matter) apart. If they were always 29 feet apart, then yes, this could be done with one label and an expression to add 29 to the station. You could also set up another expression, some lines & a block to take care of the double leader.
But I very much doubt that you are always dealing with a 29' length. So you would have to copy the label and expressions for every instance, or for every change in the design that needed to change the length. At that point you're just as well off to use mtext.
I recommend setting up a station label with small text on a no-plot layer. Then you can leave the label there as a visual reminder, but just use a leader or whatever you have been doing for this label.
Mark Green
Working on Civil 3D in Canada
You could label the first station. Than edit the Label text to include the second station and the rest of the note. You'd have to draw the second leader separately.
If you wanted to go to the trouble. You could create a separate alignment between those point. Then create a label with components for the start and end of the alignment. That would get both stations in the label.
Allen Jessup
Allen Jessup
CAD Manager - Designer
