Is there any type of label that you can attach to a feature line; such that it labels a vertex elevation dynamically (so it changes if the elevation changes)?
Solved by AllenJessup. Go to Solution.
I have a Point Elevation in a Note Label style but it's not dynamic. If you have a surface created, use a spot shot that reads the surface at the feature line vertex point.
Make a Line Label Style with a component using the General Segment Start Z.
This will label everything except the last vertex.
Allen
Allen Jessup
CAD Manager - Designer
Thanks Allen & Vincent! Appreciate your help, I will try making a line label style!
Tom
BTW. You can label the last Vertex by using the General Segment End Z and labeling the end of the FL by Single Segment rather than Multiple Segment.
Also: Be sure to Anchor the component to the Start or end as appropriate. Start for the Start Z and End for the End Z.
Allen
Allen Jessup
