Don't normally do road work so this might be a dumb question but... I have an exisitng road in plan view & have an EG surface with profile & sections, i.e. no corridor or FG profile. I need to label EOP & ROW & some odd and assorted things in plan view in section. Elevation is not critical, I just need to show where ROW & various utilities intersect my existing surface in section view & in an ideal world, label it. I've looked at coridors & adding alignments & baselines but is there a better way?
Solved by AlmasSuljevic. Go to Solution.
Hi Doug_000,
Here is a 3-part series showing step by step how to do this: http://beingcivil.typepad.com/my_weblog/2010/12/vertical-markers-for-row-and-eop-setting-up-labels-a...
I hope it works for you.
Thanks Almas, that looks like what I'm after. I'm headed down that path. will post if I have questions.
Thanks Matt, I was actually looking for that command before I posted. looking in the section menu & couldn't find it. jsut checked help menu & told me to look in the ribbon (old habits are hard to break). I've went through Almas' method & it did work. I have a variable ROw so I have to modify it to expand & target the ROW alignment but I have some other stuff that may work better using your method.
Yeah, menus are DOA, nothing in there. The sooner you wean yourself the better 🙂
works great. only one question. is there a way to project to all the sections at once? I'm using 2010 & when I select all of them & project, it only goes into one.
Maybe I missed something.
I would like to represent ROW using Feature Lines - except - I would prefer the ROW Feature Lines to be within an externally referenced DWG.
Is there maybe a setting somewhere to let the project-to-multi-section-views function access xreffed Feature Lines?
I wonder if maybe the developers are considering expanding data shortcuts to include certain feature lines like ROW lines - would be useful.
I encountered the same problem trying to apply targets within assemblies - cannot access object within externally referenced DWG - although - one could represent ROW with an Alignment and data share that ..
Mark Green
Working on Civil 3D in Canada
