Civil 3D Forum
Label curve radius via label set
9 REPLIES 9
Message 1 of 10
neilyj666
10104 Views, 9 Replies
I have manually added labels to an alignment curve to show radius/distance - is this possible to do automatically via a Label Set?? If so, how do I do it
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
9 REPLIES 9
Message 2 of 10
AllenJessup
in reply to: neilyj666
Set your default label style to Distance over Radius or your equivalent. Go to Annotate > Labels & Tables > Add Labels > Alignment > Single Segment. Select the arc and that should add the Label you want.
Allen
Allen Jessup
CAD Manager - Designer
Message 3 of 10
neilyj666
in reply to: AllenJessup
That's how I did it - I wanted to know if this was possible to do in the same way that chainages and tangent points are added as part of the Label Set??
Message 4 of 10
AllenJessup
You would do that with Multiple Segments instead of Single Segment. But I can't figure out where to change the Label Style. My Default is set for Distance over Radius. But I keep getting Delta, Radius, Tangent and Length.
Allen
Allen Jessup
Message 5 of 10
AllenJessup
OK. If I use Multiple Segments from Line Curve instead of Alignment. It uses the Distance over Radius Style. I still don't see where to change it for the Alignment set.
Allen
Allen Jessup
Message 6 of 10
AllenJessup
Got it. You need to change the Feature drop down to Alignment instead of Line & Curve.
Allen Jessup
Message 7 of 10
neilyj666
Excellent - thanks
Message 8 of 10
neilyj666
I've modified my style to only show the radies but the straights are still getting labelled (easy enough to Select Similar to delete them though)
Message 9 of 10
AllenJessup
You could just make a  _NoDisplay Line Label Style and remove all the components. Then all you'd get is the curves. Or is that what you've done?
Allen
Allen Jessup
Message 10 of 10
asankaHW
Thanks for this solution, I just used it today. Cheers!
Rail Community
