If anyone has an answer to this that would be great. I am still getting this message. I have a file named IMP referenced into my SHT file and when I zoom extentens "Label Contains Broken Reference" appears. It says it is coming from the IMP file but when I open the IMP file I don't have that "Label Contains Broken Reference". I don't even have any labels in my IMP file.
I am using Civil 3D 2014.
I think I may know the source of your problem. I can make this happen in all versions of the software including 2015. I have 3 drawings (DwgA, DwgB, and DwgC). I take DwgA and xref it into DwgB as an overlay, then label it. Then I xref DwgB into DwgC (as an attachment or overlay - doesn't matter), zoom extents, and voila. . .I've got the "Label Contains Broken Reference" on my screen. The issue is happening because you're xreffing with overlays.
Let me know if that's the case,
We are having the same issue. It seems it just started happening this week. We've been adding lables thrugh Xref (overlay) for many versions and never had this issue before. For once, when I deleted labels that was added to pipe network items outside of Xclip, it removed this message. but it showed up again. At this time, I don't have lebels outside of Xclip'ed area. It is annoying because when you do Zoom, extent, it pan back all the way to 0,0,0.
@Haruko-CTQ, do you have several xrefs as stated in my example above? Does it allow you repair the broken reference?
I realize this is a very old thread, but just seen the "Label contains broken reference" message, for the first time ever using 2016 SP2.
@Anonymous I think you've described exactly what's happening.
When attaching a certain survey dwg (which contains many C3D labels) as an Xref, the "Label contains broken reference" message appears at the crosshairs.
Once attached "Label contains broken reference" is also displayed in the drawing near 0,0 when zooming extents.
I'm working in Civil3D 2020 and this is the first time I've ever seen this error. The odd part is that I have multiple tabs with multiple viewports in each tab, yet the error message only occurs in on of those 4 viewports. This same .dwg is being referenced into about 30 other files, yet there is only one instance of this error.
