Civil 3d 2014 beginner, so this is probably a simple question -
In the Label Style Composer I don't get a tick component option.
I'm using the delivered Point#-Elevation-Description label style and trying to change the size of the tick.
What step am I missing?
Tom F.
Solved by Jeff_M. Go to Solution.
You are showing the Label portion of the Point Object. There are two things to a Point Object and the other is the Point Style, perhaps this is what you are speaking of.
Bill
Hi Bill,
I'm still figuring out how a label style relates to a point style. I was able to change the X to a + in the Point Styles and that worked, but the preview under label styles still shows an 'X'? Been through the help backwards and forwards, looks like it's time to buy a book.
Tom F
