Matt,
I have experienced the exact same problem. What I have found is that
when dragging a composed label, the dragged state (if using stacked
text) sometimes gets jumbled, but the jumbled order is actually the
order that each component was created when making the label. If you
have created the label components in exactly the order you want them
displayed, then no problem. But if you create the components then
decide their order (position in the stack), dragging the label reflects
the creation order, not the intended order.
Confused? Me too. To fix it we go back and recreate the label
components in the order we want them to appear in the stack. To avoid
it we decide order first then create the components.
Looking at your example, it seems possible that you made all of your
text components first, then your 'text for each' components, then
decided order. When dragged, it reverted to the order of creation.
nzeeben's post did not reveal the same error probably because he created
the components in the order of intended display?
CJ
Matt Castelli wrote:
> When my structure label enters a drag state it seems to “forget” the order of the components that make up that label (see attached image). The dragged state is set to use stacked text, switching it to “as composed” keeps the order of the components, but I loose the ability to drag the label to the left without a leader running through the middle of the label. Am I missing a setting? Any ideas? Thanks ahead of time!
> Matt
> C3D 2007
