neilyj
Message 1 of 8 (997 Views)
Label assembly with field automatically
997 Views, 7 Replies
02-21-2011 07:48 AM
Found a link to some code (http://c3dxtreme.blogspot.com/2010/12/automatically-label-those-road.html) to automatically place an Mtext field to label assemblies. It was written for C3D 2009/2010 but I can't get it to work for 2011 - any VBA gurus care to take a look to see if it will run (or not) on 2011
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Jeff_M
Message 2 of 8 (981 Views)
Re: Label assembly with field automatically
02-21-2011 09:21 AM in reply to: neilyj
Well, I was able to modify the file so it works in both 2009 & 2010. The same file should work in 2011, but I can't test it because I do not want to install the VBA enabler. I've made a few other minor changes as well, but since Justin is the one who posted this routine I feel I should ask him if he'd like to post the revised file or if he wouldn't mind me doing so here. I've sent him an email asking just this....
Valued Mentor
KirkNoonan
Message 3 of 8 (969 Views)
02-21-2011 11:57 AM in reply to: neilyj
Wow, quick work gettingthat link killed!
Jeff_M
Message 4 of 8 (963 Views)
02-21-2011 12:37 PM in reply to: KirkNoonan
The link is exactly how it's posted on the blog. I think there's a problem there, not with someone "getting it killed". :smileyhappy: Here's a link to the page it's on: C3DExtreme
Justin has granted permission for me to post the updates here.
Attached is a zip file with both a VBA and Lisp version of the code. Either should work in any version of C3D. There is a Readme with a little more info.
neilyj
Message 5 of 8 (930 Views)
02-22-2011 12:26 AM in reply to: neilyj
Many thanks Jeff_M (and Justin) for the quick turnaround to this request - I've just tried the lisp version and it works perfectly
PS in the original link I posted, an extra bracket had crept in at the end so the link didn't work
neilyj
jmayo
Message 6 of 8 (910 Views)
02-22-2011 05:03 AM in reply to: neilyj
Thanks for the additional work of the lisp version. I've been coping mtext objects from assembly to assembly and editing the field. I'll give it a shot in a bit.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Distinguished Contributor
onsionsi1
Message 7 of 8 (469 Views)
12-30-2012 03:18 AM in reply to: Jeff_M
I tried to try VBA with Civil 3D 2012 and it didn't work
Thank you in advance.
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
Jeff_M
Message 8 of 8 (456 Views)
12-30-2012 07:44 AM in reply to: onsionsi1
A little more information would be helpful. "It didn't work" is not very descriptive. Were there any error messages or warnings? How did you load and run it? DId you try the lisp version?
I cannot test it in 2012 because I did not, nor plan to, install the VBA Enabler.
