Hi guys,
Can i design junctions and roundabouts in Civils 3D without using the Wizard?
Dan
Yes. Simply create the requisite alignmets, profiles and assemblies to construct the desired corridor
Joe Bouza
Perhaps this hand-out form an AU 2008 class could be of help..
Dan,
Here's another place to look; Tim Corey's Blog:
http://timsc3dblog.blogspot.com/2014/10/corridor-intersection-primer-manually.html
Dave
Dave Stoll
Las Vegas, Nevada
I generally prefer to create intersections manually. My process is a little different than most people, I use superelevation parameters to specify the cross slopes of the return which means that I don't have to create and maintain curb profiles.
A couple of years ago I did a course at Autodesk University on this topic. Search for CI2160 - Intersections from the Inside Out.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
