Civil 3D Forum
Join Two Different Assemblies at same point
1 REPLY 1
Jason.Kroll
384 Views, 1 Reply
Hi
I have two different assemblies, one has a normal batter slope to a table drain or embankment and the other is a kerb and channel. Refer attached.
When you apply these two assemblies in ajoining regions, I get both assemblies at the same point, which causes the corridor surfaces to incorrectly triangulate.
Is there a way to stop this from happening.
Thanks.
Jason
1 REPLY 1
Neilw_05
in reply to: Jason.Kroll
You'll need to create a gap between the 2 assemblies. The corridor will show the gap but the surface model will triangulate between the ends of the strings.
If you can't live with a gap in the corridor you'll have draw lines to connect the strings across the gap and use them as targets for the subassemblies.
Corridors do not support automatic transitions.
A search on the topic "transitions" will provide a wealth of info on this question.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Rail Community
