Civil 3D Forum
Jog Profile Labels
26 REPLIES 26
Message 1 of 27
Cre9engr
1937 Views, 26 Replies
Jog Profile Labels
Is there a way to insert a jog into a profile label?
Fred
-Civil 3D 2016 sp2
-Windows 7 64-bit
-Intel Xeon with 3.5 GHz
-16 GB of RAM
-Nvidia Quadro K2200
-Civil 3D user since 2007
26 REPLIES 26
Message 2 of 27
mathewkol
in reply to: Cre9engr
It would be helpful if you included a sketh of what you're looking for.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 3 of 27
Cre9engr
in reply to: mathewkol
Something like the attached images. There is both a before and after image. I would like to be able to do with this with some sort of dynamic label that allows the user to adjust the jog distance by selecting a grip or entering a distance in the command line.
Fred
-Civil 3D 2016 sp2
-Windows 7 64-bit
-16 GB of RAM
Message 4 of 27
Cre9engr
I think I partially answered my own question.  I found how to stagger labels within the properties box.  How can force the stagger to occur at a certain location from the attachment point?
Fred
-Civil 3D 2016 sp2
-Windows 7 64-bit
-16 GB of RAM
Message 5 of 27
Cre9engr
Yup.  I found my own answer.
Fred
-Civil 3D 2016 sp2
-Windows 7 64-bit
-16 GB of RAM
Message 6 of 27
Cre9engr
Next stupid question.  Is there a way to jog/stagger the vertical curve labels?  See all my previous images if you want to know what I'm looking for.
Fred
-Civil 3D 2016 sp2
-Windows 7 64-bit
-16 GB of RAM
Message 7 of 27
Joe-Bouza
The stagger settings did the 1 grade break label? I couldn't get it the do anything, and help speaks of it for data band use. could you explain what you did?
Joe Bouza
Message 8 of 27
losfotos
So since you found the answer... what is it?
Edit: Never mind I see your solution.
Carl Simpson
C3D 2015 & 2016
Message 9 of 27
Joe-Bouza
I cant get it to work and I copied your settings. How did you do it?
Joe Bouza
Message 10 of 27
losfotos
in reply to: Joe-Bouza
I haven't been able to figure out manual jogs on profile labels yet. I'm mostly interested in doing it with structure labels. Super frustrated at the moment.I've just been making new label styles as I need them but that is just stupidly cumbersome.
Carl Simpson
C3D 2015 & 2016
Message 11 of 27
jmayo-EE
in reply to: losfotos
With stc's I anchor the labels to a vertical line and insure that the dragable state is set to 'as composed' so I can drag the label (still attached to the vertical line). I then draw a line to create the jog and match props to get the line on the label layer...a jog function would be real nice for the stc lbls.
John Mayo
Message 12 of 27
Joe-Bouza
in reply to: jmayo-EE
Your method got me to thinking about the OP's grade break. If you made two grade break label styles style01 is only a 1" Line.1 anchored to the feature and style02 with data anchored to line.2 as composed attached to line.1. Then when you drag style02 from the other would it create a jog line to the end of style01? I'm home so I hypothesize 🙂
Joe Bouza
Message 13 of 27
Neilw_05
I haven't tested your idea Joe but whenever a label goes into dragged state the leader points to the feature and all lines, etc. in the style disappear.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 14 of 27
Joe-Bouza
in reply to: Neilw_05
Ok, but the idea should enable a manual jog by pull styleo2 from style01 and manually connect the two. I'll try it on Monday
Joe Bouza
Message 15 of 27
troma
Hmm, try this...
Turn off the leader,and set your dragged state to 'As composed'.
Set up a label that has an invisible 'Tick'  component.
Add your text component.
Add a line; one end attached to the Tick, the other end to the text component.
If you drag this label, the line should hold one end at the Tick location, and let the other end be dragged around with the text.
I have something like this working with a 'Note' label; I imagine it should work with others too.
Mark Green
Working on Civil 3D in Canada
Message 16 of 27
losfotos
in reply to: troma
Not that this helps one bit, but of all profile labels it seems that structure labels should be draggable without having to create all these workarounds.
Carl Simpson
C3D 2015 & 2016
Message 17 of 27
Neilw_05
in reply to: troma
I tried your suggestion but can't get it to work.Can you post your style so I can analyze it?
WIN 10 64 PRO
Message 18 of 27
troma
Like I said, this is a note label.  I assumed the same method would work for others.
This is the same label in the original and in dragged-state:
Mark Green
Message 19 of 27
Neilw_05
in reply to: troma
Thanks for posting your example. As I was reviewing it I suddeny l realized that we can already add jogs to dragged label leaders, so what are we gaining by creating a style to do the same thing?
WIN 10 64 PRO
Message 20 of 27
troma
We don't use leaders for profile PVIs or for structure labels in profile. We don't have any lines at all for them, so we can drag the text sideways a smidge if necessary and you don't even notice the difference. No leader, everything 'as composed'.
The only reason I posted was in response to your comment "whenever a label goes into dragged state the leader points to the feature and all lines, etc. in the style disappear." This is a style where the line does not disappear in the dragged state. That's all.
(This style also creates a straight leader with no landing, useful for certain places.)
Mark Green
Rail Community
