We want to show the Existing elevations, Profile2, labels in italics. I would have expected to be able to edit the Band Style, compose the Major Station label, delete the Elevations component and add 2 text components one for profile1 elevations and one for profile2 elevations. Then assign a different text style to each. But I can't create a new text component that has a Contents field. Even if I copy the Elevations component, the new component doesn't have the Contents field.
Is there an alternate way to do this?
Allen
Allen Jessup
CAD Manager - Designer
Solved by kthuynh. Go to Solution.
I believe if you select the "format" tab, you can overwrite the font style. Only certain fonts can be Italicized.
Thanks. I was totally missing that!
Allen
Allen Jessup
