I think I do. My machine is 7 years old. I am currently running AuoCAD Civil 3D 2011. I use my machine a lot for preliminary designs, so I import many images from ArcGIS or from aerial fly overs to use as a base. The image sizes are fairly large, some aerial tiles can be 200+mb. I believe we will be updating to 2013 or 2014 soon. Here are my specs:
From "My computer":
System: Microsoft Windows XP Professional Version 2002, Service Pack 3
Manufactored and supported by: Gateway E-4500S
Intel ® Pentium ® 4CPU, 3.00GHz
1.99GB of Ram
Thanks for the help!!!!!!
-Luca
Check out the system requirements page. Looks like you need more RAM if you upgrade just to meet the minimum, and the minimum isn't really enough if you have large data sets. I don't know anything about ArcGIS, I'm sure others will comment, but this link should be a good starting point.
Mark Green
Working on Civil 3D in Canada
As for the OS you are using possibly the worst available option IMO. Even if it's 64 bit then it's the second worst option. Your PC does not meet the min requirements for 2014, you are at the bare min requirements for 2013. I would not want to pay someone to use CD on your PC. I would waste too much time and money to crashes and slow performance.
I would not recommend anyone running CD with the bare min. requirements.
John Mayo
Agreed, and with C3D 2014 XP is not a supported OS, ONLY 64BIT Win 7/8.
Upgrade your OS. Win7 64. Best thing you could do if you can't get a new computer.
After that, upgrade your RAM. I would recommend 8GB minimum. On my system I have 32GB and with some of the data sets provided by my customers, I've come close to maxing it out.
Luca, before any other decision, read these ones:
your IT guy doesn't actually use the software, does he? I am a designer and IT guy; two years ago we upgraded from a very similar setup (WinXP, 4GB RAM, Pentium 4 - 3.4GHz) to Windows 7 Pro 64-bit and 8GB of RAM (this only cost us about $400/workstation). The number of fatal errors we were getting went from 3 or more per user per day, to 2 or less per user per week. We were finally able to replace our 6-7 year old workstations with all new custom built workstations (for about $1400 each) so we can upgrade to 2014. For what you are doing, I would recommend a Core i7 3770k or better, a minimum of 16GB of RAM, a 256GB SSD, and, if cost is an issue, a high end consumer video card which will only cost you about as much as an entry level workstation video card (we are using AMD Radeon HD 7950 3GB cards and haven't had any problems whatsoever). Hope this helps
Guys,
Thank you for the responses! The IT guy kept giving me "Well, your machine has the minimum requirements established by the program" speech. So I'm hoping your comments will be able to shed some light. He tried telling me that he would buy a desktop with 4GB ram, and replied by telling him that it would be a complete waste to buy a machine with just 4GB ram. Oh well, hopefully this does the trick. Thanks!
4 GB RAM is borderline for a computer running x64 Win7 and a couple of desktop applications like Word or Excel. For simple CAD work (e.g. 2D schematics) 8 GB would be considered a minimum. For data-intensive work like Civil 3D 12 GB is usually considered the lower end of acceptable (and works out nicely for both dual- and triple-channel RAM). With 8 GB sticks now commonly available there isn't much point in not getting 16 GB for a couple of extra dollars.
Don't forget about the rest of the system too - everything works together. Not much point putting a full 32 GB RAM on a 1.6 GHz processor, or using a clunky 5400 RPM hard disk with an overclocked and water cooled 4.6 GHz processor, for example.
I wouldn't want to cause problem for you, but if your IT guy is telling you that, let him know that you strongly disagree with him and that you're prepared to make your case to HIS boss. If your organization gives a hoot about their production/performance, then it might not be looked down on to go over someone's head if you feel strongly enough about your ability to do your job with excellence.
I am about to get a major RAM upgrade after trying to run ArcGIS and C3D 2012 with my current machine (see my sig below). I opted out of a 2nd monitor for some dumb reason last year, so I'll also be getting one of those soon (ArcGIS alone is tough on 1 monitor!). I had several freezes/crashes yesterday and just slow performance for days. So I won't be running both juggernaut apps together until I get the RAM, which will probably be at least 12 GB.
Good luck!
Joe Bouza
We were getting the same line from our IT department after they got a minimum spec machines and I ended up doing a comparison of crashes and the cost of crashes of our minimum spec work machine versus my home machine. I passed that onto my manager and he wanted to know what we should get. We had the first one ordered within 2 weeks which is a bit of a record for where I work.
I will attach the spread sheet I used to do the comparison and the system recommendation I made at the time. Be aware these are 2 years old now so you should up the specs a bit as mentioned in previous posts.
When confronted with the potential lost wages, which does not also include the on cost, i.e. delay in construction jobs etc. my manager got IT to provide the computers I specified.
I agree with everyone else. My machine is six years old (Dell Precision Workstation 390) and has a Core 2 Duo 6400 CPU. I spent about $250 to up the RAM to 8 GB (max for this MB), and drop in a 1 TB HDD. The machine came with Win XP, but I upgraded it to Win 8 64-bit last fall. I've been running C3D 2014 since it was released, and it runs fine, but I'd say my setup is about the bare minimum for acceptably running C3D. I figure the $250 was worth it to squeak another year or two out of this computer.
Great document Andrew, very often it is best to produce these sorts of fact and figures as $$$ or £££ are the only language that "the suits" speak.
IT setup my computer to minimum requirements on ram and I had all kinds of performance issues with multiple apps open. Upgraded ram to 12 gb and the problems ceased.
Joe Bouza
Joe,
Pardon my post-3-day-weekend rant . . .
I get your point, but beefing up your fuel pump would be part of that equation. I think a better analogy to RAM (in terms of IC engine components) would be upgrading an undersized air box, MAF, throttle body, and maybe even surge tank for more air flow.
Joe Bouza
