Civil 3D Forum
Issues with grips in Civil 3D 2014
4 REPLIES 4
gambate9193
830 Views, 4 Replies
I used grips constantly for moving, copying, etc.  Normally it will allow me to use grips for a while and then all of the sudden it stops allowing me.  It will let me activate a grip but I can't do anything with it.  I try to hit escape to clear the grips but they don't clear.  The only way that the grips clear is if I start a command and then if I go back to trying the grips it does the same thing.
This doesn't happen often but when it does I'm usually in the middle of something and the only way I can fix it is to close the program and restart.  It gets annoying.
If anyone has any suggestion it would be greatly appreciated.
4 REPLIES 4
tcorey
in reply to: gambate9193
All I can add is confirmation that I have the same issue and solve it the same way.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
sangrula
I am having the same problem. Has anyone found out what is causing this?
sangrula
in reply to: sangrula
I found out that it was the "Dynamic North Arrow" that was the problem. Deleted them and now it works fine.
Jay_B
Agreed, I had this problem a while back too, see this related thread.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Rail Community
