I used grips constantly for moving, copying, etc. Normally it will allow me to use grips for a while and then all of the sudden it stops allowing me. It will let me activate a grip but I can't do anything with it. I try to hit escape to clear the grips but they don't clear. The only way that the grips clear is if I start a command and then if I go back to trying the grips it does the same thing.
This doesn't happen often but when it does I'm usually in the middle of something and the only way I can fix it is to close the program and restart. It gets annoying.
If anyone has any suggestion it would be greatly appreciated.
All I can add is confirmation that I have the same issue and solve it the same way.
@Anonymous wrote:
I found out that it was the "Dynamic North Arrow" that was the problem. Deleted them and now it works fine.
Agreed, I had this problem a while back too, see this related thread.
