Civil 3D Forum
Issue with Structur heigths
2 REPLIES 2
office
341 Views, 2 Replies
when i try to lower the height from an Standard-Catalog-Structure "DACH Metric Structures - DACH Abwasserkanalschächte - AeccStructEccentricCylinder_Metric_Dach" it block at an certain level (1,622m).
With a diameter of 1000 mm there are products available with an height rim to cone top of an 1,05 m. why I not able to create this? (doesn't work with similar objekts from the Catalog)
I tried to find limits which might be possibly set in the Component-Builder, but found non.
Win7 64bit
HP z400 Workstation
ATI FirePro V4800
C3D2013
2 REPLIES 2
Christian_Bauer
in reply to: office
Please correct me, but this is due to the Parameter "Vertical Pipe Clearance" (SVPC), which controls the minimum Height of your Structure, which does not allow to have a Height less than this.
The "Vertical Pipe Clearance" is computed by: SVPC = SFH + SCH + SBPC
SFH Frame Height (List) 160 or 200 mm
SCH Cone Height (List) 600 mm
SBPC barrel Pipe Clearance (Constants) 600 mm
HTH
Christian Bauer
office
in reply to: Christian_Bauer
I tried this already, but it seem to be needed to oversize the element in first place and then switch to gain height by DEM (DGM).
Thanks for the quick support.
Win7 64bit
HP z400 Workstation
ATI FirePro V4800
C3D2013
Rail Community
