I discovered a weird thing that seems like a bug...I tried to hatch manually while in profile view (couldn't figure out how to do what I want with the profile view hatching options) and it seems that if I try to make one hatch (by picking internal points) that includes multiple structure profiles on the same profile view, the first structure profile for that profile view works as a hatch boundary, but subsequent structure profiles are basically ignored if I keep trying to pick internal points to make a composite hatch.
I assume it's because of this same bug that I can't create a hatch by choosing boundary objects and using two structure profiles in the same profile view as boundary objects.
Has anyone else experienced this/does anybody know how to resolve this? Or, if anyone could help me figure out how to hatch using the profile view hatching and to use a pipe network as a boundary, that would also be helpful.
Strange final thing to note...if I hatch by picking internal points, and pick one area with a structure profile as part of the boundary, and then I pick a similar area in a different profile view, everything works fine...it's just the second (and though I don't have more than 2 structures per profile view in my drawing, I would assume any subsequent) structure profiles that I try to use as hatch boundaries that AutoCAD is basically ignoring.
Joe Bouza
Basically I want a hatch in my profile view that updates dynamically using my pipe network as one of the boundaries.
I tried doing it using the hatching feature built into the profile view object, and I also tried doing it manually (which is the method I was primarily referring to in this post) as well. I haven't been able to make either method work.
Joe Bouza
I'm trying to hatch an area between the pipe network and a surface profile.
I know the profile view hatch feature doesn't work directly for pipe networks...I was hoping maybe I could find a work-around.
Joe Bouza
Ok, maybe projecting objects to profile view will work for you? and they would be dynamic. wouldn't be a hatch but you could get some kind of flag to show the limits of the wetlands.
Joe Bouza
I know this is an old post but I just came across it myself. Same type of issue with hatching in a profile that shows a pipe network in crossing. In my case using the hatch option in the profile view (to show the area in fill) between finished grade and existing ground and around the pipe crossings (from the pipe network) not through the pipes. I guess in short is there some sort of part masking for crossings in profile view?
Mike
