Active Member
mwhosey
Message 1 of 11 (824 Views)
Issue deleting triangle lines in a surface
824 Views, 10 Replies
11-08-2012 10:39 AM
I'm trying to modify a surface I created using drill hole data of a cavern.  When I select the delete lines command for surface editing a message pops up telling me that I must have the triangles displayed in the surface style dialog.  But I do have the triangles displayed, and it still gives me the same message.  Has anyone encountered this before and know of a solution.
neilyj
Message 2 of 11 (808 Views)
Re: Issue deleting triangle lines in a surface
11-08-2012 12:05 PM in reply to: mwhosey
Is it a data shortcut surface or is it natively in the dwg file? Can you post the file??
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
jmayo
Message 3 of 11 (793 Views)
11-08-2012 02:05 PM in reply to: mwhosey
This message should really say 'Triangles need to be displayed in plan view'. If you are displaying triangle in model/3d only try turning them on in plan.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
BrianHailey
Message 4 of 11 (784 Views)
11-08-2012 04:19 PM in reply to: mwhosey
My recommendation (and this is not an answer to your question) is avoid using these type of edits on your surface. Instead, draw a polyline touching the triangles you want to delete and then add that as a boundary and uncheck "Non destructive breakline" (I suppose that makes it destructive?). This will give you much more control on your surface then deleting triangles.
Brian Hailey
CAD-1.com
My Blog
Active Member
mwhosey
Message 5 of 11 (727 Views)
11-20-2012 06:55 AM in reply to: mwhosey
neil,
the surface is not a data shortcut, made it from points inserted from point file.
john,
the only place I know to display the triangles from is the surface style dialog, under the display tab, turning on the triangle light bulb.  not sure if this turns them on in plan, seems like if they are displayed in model (where I'm working) then it should work.  don't know how to go about displaying them in plan.
brian,
I think yours is the best answer, but I don't think a poly line will be sufficient.  Let me try to explain, the cavern is in the shape of an elongated egg (file attached for visual aid), and I want the surface to be the shell of the egg.  but C3D is making the triangles of the surface extend across and through the egg's center instead of only around the outside (shell).  It seems in order for you solution to work I would have to make a secondary 3d egg shape boundary inside the cavern to block the triangles from shooting across the center.  I don't know if that is possible but will try it and see.
Active Member
mwhosey
Message 6 of 11 (722 Views)
11-20-2012 07:05 AM in reply to: mwhosey
Well, turns out you can not make a 3d object a surface boundary.
jmayo
Message 7 of 11 (720 Views)
11-20-2012 07:07 AM in reply to: mwhosey
I'm opening your file now. You need to turn the triangles on in plan. Note there are 3-4 display modes for C3D object styles. See the attached. Hit the dropdown arrow and select which mode (plan, model, profile or section) you want to edit. Right now your triangles are turned off in plan.
John Mayo, PE
IDSP 2014
jmayo
Message 8 of 11 (717 Views)
11-20-2012 07:09 AM in reply to: jmayo
Also note that you will still be able to select lines to delete in a 3d view. Triangles just need to be displayed in plan.
John Mayo, PE
IDSP 2014
neilyj
Message 9 of 11 (715 Views)
11-20-2012 07:10 AM in reply to: mwhosey
You won't tbe able to model a cavern i.e. floor, sides and roof in one surface as the triangulation algorithm does not allow this. As a workaround, you may have to construct several surfaces (Floor, left side, right side and roof) but they will always be seperate.
The AutoCAD solid modelling tools may be more appropriate to this type of task
neilyj
jmayo
Message 10 of 11 (706 Views)
11-20-2012 07:16 AM in reply to: neilyj
I agree Neil. Either multiple parts (I would try a top and bottom) or AutoCAD Solids.
John Mayo, PE
IDSP 2014
