Is there some way to turn off contours above a certain elevation?
Solved by Joe-Bouza. Go to Solution.
You could extract specific countours and use them as surface boundaries (working this would vary greatly on the contour geometry).
You could also extract a contour at the cut-off elevation and use it as a surface mask. It will not be dynamic, however.
Joe Bouza
To be more specific: under surface propertires>> analysis>> contours; choose 2 intervals and set the elevations of the unwanted and wanted. pick a no plot color (255 in our shop) for the major an minors, and plot colors for the other major minors. Important! edit the surface style >>contour tab>> contour intervals>> say "True" to use color scheme.
totaly dynamic
Joe Bouza
If it needs to be dynamic, limit the elevation in the surface properties (Definition>Build>Exclude Elevations greater than).
I'd be carefule with that approach.
That will alter the triangulation and the results may not be the exact surface.
Joe Bouza
Joe Bouza
totaly dynamic
I'll take Joe's suggestion a step further. Create a linetype that places 1 single dot at a really high spacing. Use that linetype for the contours that you don't want to see. You shouldn't even see them on screen (unless acad forces it to display a continuous linetype).
Don Ireland
Engineering Design Technician
totaly dynamic
Joe,
Maybe you can share some info as to how you did that? I attempted to use it but apply the linetype suggestion I made earlier. I can't even get it to change contour colors.
I created two contour ranges: one below and one above 570. Then I made the second one magenta and the first green/cyan. But no matter what, they remain RED.
Don Ireland
P.S. I don't see the setting you mentioned -- maybe that's why?
EDIT: After posting that, I got to wondering if there might be some other place to find that setting. I found it.
Don Ireland
Joe Bouza
oh. Thanks. Having found the setting, I applied the linetype suggestion.
It does reduce the visibility of the contours (on screen) and Joe's suggestion will make the contours not plot at all.
Magenta & Dotted is below 570 and Cyan/Green & continuous is above 570.
Don Ireland
HTH
Please select "accept solution" so other readers may be aware of your solution
Joe Bouza
