Solved by btillett. Go to Solution.
You just need to use the Follow Surface command (FOLLOWSURFACEINPV). I did not see this ribbon or know about this command for a while. But it is there. When you select Edit Network on the pressure Networks:Water ribbon you have two choices, one to use “Plan Layout Tools” and the other to use “Profile Layout Tools”. Select the “Profile Layout Tools” (EditPressureNetworkInPV) and you will find a follow surface command. This command seems to do what you say you are doing manually, it breaks the pipe up into 18’ segments and follows the surface quite nicely.
I hope this helps.
