I'm using Civ3D 2014 and I'm looking for a way to import layer properties filters from another drawing. I saw some old posts on this topic but never found a good answer. Any help would be appreciated!
Solved by neilyj666. Go to Solution.
LAYERSAVEFILTERTREE and LAYERLOADFILTERTREE should do the trick for you.
neilyj (No connection with Autodesk other than using the products in the real world)
