like a +1% slope from the outside lines towards the center line
Solved by neilyj666. Go to Solution.
maybe my method is wrong, so the outside line is a feature line, then i used the grading tool to make it 1% slope towards the center line, then i add to surface as breakline and it comes out like that. i want the inside to be uniformed with the grade, not like how it shows.
Like this?
I just used a feature line to do this but I can't quite work out how you are using the grading trools for this?
Your Name
Your Name
Your Name
Your Name
