Is there a limit to nested pasted surfaces?
I have "Surface 0" which I paste into a new surface with another surface to create "Surface 1". I then paste "Surface 1" into a new surface with another surface to create "Surface 2". I then paste "Surface 2" into a new surface with another surface to create "Surface 3". etc...
It seems to stop working after 4 "nests". "Surface corrupt...run recover", or "Could not open referenced surface for surface" error.
I don't know what else would cause these errors. Boundaries are fine, surfaces are all fine by themselves.
I've never heard of a limit but, there could be.
Perhaps test it with some very simple surfaces and see if you get the same result.
I stopped at ten nested surfaces (top plus nine) with no errors. Admittedly, my surfaces were made from a single rectangle, but the point was to see if there is a limit to how many nestings you can do. The answer is, "At least ten."
Tim
Tim
The answer is, "At least ten made from a simple rectangle"......;)
Joe Bouza
