Civil 3D Forum
is possible to create open pit in civil 3d?
11 REPLIES 11
Message 1 of 12
alexandre_ssp
2491 Views, 11 Replies
https://www.youtube.com/watch?v=gF65b_khSCg
https://www.youtube.com/watch?v=UlMjVrq43rQ
video follows the creation open pit design
I wonder if it is possible in civil 3d
any tutorial?
11 REPLIES 11
Message 2 of 12
tcorey
in reply to: alexandre_ssp
I doubt it will be as automated as a software made specifically for pit design, but you can certainly get the job done with Civil 3D.
Create a feature line at the bottom of the pit and use stepped offset to build the benches. Make a surface from those feature lines.
Create a corridor for the road and a surface from that corridor.
Create a blank surface, paste the benched pit surface and then the corridor surface.
Voila! It's the pits.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 12
alexandre_ssp
in reply to: tcorey
unfortunately the civil 3d leaves much to be desired in this part
Message 4 of 12
neilyj666
Comparing Vulcan and Civil 3D is like comparing apples with oranges as the packages are totally different and designed for different applications. Vulcan is a very specialised mine engineering program whereas Civil 3D has wider applications and a broader user base with many different workflow requirements.
Should someone feel the urge to do a lot of coding I'm sure a lot of automation could be achieved within Civil via .NET etc but until then, as Tim said, it can be done in Civil 3D but it is a very manual process...Smiley Happy
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 12
I agree that are aimed at different areas
civil 3d but not updated since the grading its creation
carlson software as the vulcan amongst others is automatically grading
civil 3d manual continues until today
Message 6 of 12
neilyj666
Open pit design is a much harder marketing sell compared with fully rendered road schemes and buildings which is what you always see in the Autodesk promotional material....
Message 7 of 12
alexandre_ssp
in reply to: neilyj666
work in mining area
quite civil 3d use
a very useful software
I know thousands of people who use civil 3d in mining
I think autodesk should see mining as customer
Message 8 of 12
Coudnt agree more Alex. There is a lot Civil 3D developers could learn from these mining applications that could be applied to both the Landfill/Urban Development and Mining/Dam Design customers like you and me who are using Civil 3D exclusively.
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
Message 9 of 12
juanchooo50
estoy haciendo una investigación acerca de la utilización de civil 3d en minería tanto en cielo abierto como bajo tierra, y quisiera saber si alguien tiene información o conoce a alguien que trabaje en este tema.
Message 10 of 12
caudata
in reply to: juanchooo50
Hola Juan! Utilizamos AutoCAD Civil 3d en mineria. Pero usamos los "plug-in"es porque hemos concluido que para mineria seria hay que perfeccionar civil seriamente en esta question. Tenemos muchos plug-in'es (para mineria a cielo abierto y subterraneo) pero no los vendemos porque de vez en cuando surge la escripcion "fatal error"... Pero eso no influe a nuesro entusiasmo, los mejoramos casi cada dia.  Y a decir verdad todos nuestros plugins "hablan el ruso", pero si te interesa, por ejemplo nuesto el ultimo plug-in:
https://youtu.be/GcvDWGymUfs
Excuse me for my terrible Spanish 🙂
Message 11 of 12
Caudata could make mining plugins available for learning
Grateful for the attention
Message 12 of 12
alexandre_ssp
in reply to: caudata
Could you share the plugin mine ?
Не могли бы вы поделиться плагином?
Благодарен за внимание
Rail Community
