Is it possible to make a bench right before the daylight line meets the top surface (Original Ground)?
The Road prism is a tylical shape that has a u-shaped ditch on one side. The daylight line from the outside edge of the ditch follows a series of comlicated benches at set elevations and then terminates at OG with no trouble but I'm trying to get an additional bench to be generated before OG (see attached + yellow lines).
Anyone have any idea how to add this extera bench?
Solved by sboon. Go to Solution.
It should be possible. Try this:
Great! thanks for the reply.
Only thing is that it doesn't quite work the way i have it set up. I'm sure i have it set up wrong but I thought I'd run it past you since it looks like you have it already working.
1.) So from the end of the last bench (green dot from your picture) I've added a 'MarkedPoint'.
Marked Points Properties - Point Name = BL
2.) From the 'MarkedPoint' I added a 'LinkSlopeToSurface' with a slope of 63 Degrees. Coded as P2 with the Omit Link set to No.
3.) From the 'LinkSlopeToSurface' I added a 'LinkOffsetAndSlope' subassembly with paramiters:
Offset from Base line 1.5m
Slope Direction: Towards Crown
Slope: 63 Degrees
Point Codes: BL
Omit Link: No
This allowed the Orange dot to move in the right direction i think, at least visually.
4.) From the 'LinkOffsetAndSlope' i added a 'LinkToMarkedPoint'
Marked Point Name: BL
5.) then i added a 'LinkWidthAndSlope' with a 'LinkSlopeToSurface' to create the last bench. Only I'm sure I made a mistake because it doesn't work.
Do the subassembly properties make sence to you or should they be something else maybe? The LinkOffsetAndSlope adds a slope line 50 away?! so it's giving wierd results.
Any ideas?
From the description is sounds like you have added the links in Step 5 to the LinkToMarkedPoint from Step 4, instead of the end of the link from Step 3. It may help at this point to delete the LinkToMarkedPoint until you have the rest of the assembly working then add it back in later.
Keep in mind that it's important when adding subs to make sure of which one you're attaching to. Sometimes when there is already another sub attached to an endpoint it is necessary to use draworder to make sure that you're hooking to the end of the previous link.
either the first slope to surface doesn't work when it's set to omit link. or the link to offset tries to connect to the assembly 15m away..... i guess that means that it itsn't connected yet.... I'll keep messing with it bit any other suggestions in the mean time?
nevermind XD i got it working. I basically had to leave teh MarkedPoint and LinkToMarkedPoint off of the assembly until i had the rest of it built. Once that was done and i had a cross section taken though the corridor, I could see visually that it was going to work. The big thing the program was having trouble with was adding the ancor locations ontop of subassemblies like MarkedPoint and LinkToMarkedPoint.
Thanks for all your help. I'm glad i can finally start taking a step forward.
Thanks again.
I am having a terrible time with daylighting a bench scenario to a rock surface, then applying a simple daylight link at a different slope (in soil) to daylight to the top surface. See pic. This is what the corridor keeps modeling. What am I doing wrong? So frustrated with Civil 3d. The assembly is attached here as well.
Brad
