Civil 3D Forum
Is it possible to view the codes of a assemby (not on composer)?
4 REPLIES 4
tonnot
279 Views, 4 Replies
I'd like to view the point codes (and also the links and shapes) of an assemby I have on my c3d drawing.
I dont see nothing to get it ....
Any helps ? Thanks,
Civil 3D (2013) how much you have to improve....
4 REPLIES 4
mathewkol
in reply to: tonnot
By view them I'm assuming you mean you want to see the labels next to the link, point, and shaoe, right there in your assembly?
You will need to assign a point code style that is set up with label styles that list all of the codes.  Edit a point code style and you will see a column for label styles.  You'll need one for each; links, point, and shape.  You need to place this style in the <ddefault> section under each point, link, and shape.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
tonnot
in reply to: mathewkol
Thanks....
I can't set this ..... neither at  assemblie level neither at sumasemblie level....
Where can I do this ?
Thanks.
mathewkol
in reply to: tonnot
Your assembly has a code set style assigned to it, you need to edit this code set style.  I've attached a DWG with the codes labelled.  Your code set style will likely be named differently.
Here is what they look like
Matt Kolberg
tonnot
Ups . Of course.....
mmm something was happen I dont saw it....
But ... I'd want something easier and direct. A  context mouse could be appropiated
(maybe in the future...)
Thanks Matt
Rail Community
