Civil 3D Forum
is it possible to make an expression do this?
4 REPLIES 4
callen
384 Views, 4 Replies
I want to create a dynamic label that outputs an elevation based upon the following:
(profile elevation-(station offset*user input slope value))=elevation at a joint line.
I cannot seem to figure out how to connect the offset and profile elevation within an expression to make this work.
4 REPLIES 4
Jay_B
in reply to: callen
If you have an alignment & profile, then you shouldn't need an expression, just use an alignment "Station Offset Label" and add a "Reference Text" component for category: Profile > "Profile Elevation" in text contents on layout tab in the label style.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
callen
in reply to: Jay_B
You must have misunderstood my want.  I want to be able to determine the elevation of a joint say 10' from CL at a 2.0% slope.  I want the label to automatically use the exact offset from the alignment and a user entered slope to calculate the joint elevation from the profile elevation.
Ideally, I would add a station offset label, it would prompt me for a slope value and prompt me to select which profile and majically a joint elevation would appear.  I just can't seem to figure out how to link the offset and profile elevation together.
Joe-Bouza
in reply to: callen
You cant pause for user input.
No corridor? A corridor can target the joint lines and you can just add a surface label.
And if its existing you can still do it
Joe Bouza
Jay_B
in reply to: callen
Yes I did misunderstand your post, was thinking you were using a corridor, and already had a profile along this joint.
I missed the "user input" but like Joe, I'm confused as to what this user input is to be used for?
Can you post a sketch, showing the alignment, profile location, the joint layout and cross slope information?
There are dynamic options for labeling station and offsets along a profile or corridor surface but first we need to understand your design a little better.
C3D 2018.1
C3D 2016 SP4
Rail Community
