I want to create a dynamic label that outputs an elevation based upon the following:
(profile elevation-(station offset*user input slope value))=elevation at a joint line.
I cannot seem to figure out how to connect the offset and profile elevation within an expression to make this work.
If you have an alignment & profile, then you shouldn't need an expression, just use an alignment "Station Offset Label" and add a "Reference Text" component for category: Profile > "Profile Elevation" in text contents on layout tab in the label style.
You must have misunderstood my want. I want to be able to determine the elevation of a joint say 10' from CL at a 2.0% slope. I want the label to automatically use the exact offset from the alignment and a user entered slope to calculate the joint elevation from the profile elevation.
Ideally, I would add a station offset label, it would prompt me for a slope value and prompt me to select which profile and majically a joint elevation would appear. I just can't seem to figure out how to link the offset and profile elevation together.
You cant pause for user input.
No corridor? A corridor can target the joint lines and you can just add a surface label.
And if its existing you can still do it
Joe Bouza
