Civil 3D Forum
is it possible to import station and elevation
9 REPLIES 9
Message 1 of 10
1473 Views, 9 Replies
is it possible to manually import station, elevation and description without the northing or easting in civil3d. if yes how do i go about it
thanks
9 REPLIES 9
Message 2 of 10
Citadel2012
Are you referring to points? Alignments? Drainage/sanitary structures?
______________________________________________________________
To Err is Human; To Really Foul Things Up Requires a Computer.
Message 3 of 10
Jeff_M
Yes, but you would need to include an offset (0 would work).
http://docs.autodesk.com/CIV3D/2014/ENU/filesCUG/GUID-C395923C-8EE8-4BFB-9F02-48064B69D161.htm
Message 4 of 10
in reply to: Jeff_M
thank you sir but am using 2011 autocad civil 3d. look at what i wanted to import in civil 3d. i have attach the file.
Message 5 of 10
in reply to: Citadel2012
alignment sir
Message 6 of 10
ccoles
I used this method way back with Civil 3D 2008. Don't get scared because of the Civil 3D 2014 reference. Be sure to add a column for your offest of zero and you're set. Works like a charm. The file I worked with included more than 250 points of pulled cross-sections as part of a construction as-built I needed to verify.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
Message 7 of 10
Jeff_M
Did you look in the 2011 help? It is identical to the 2014 version I linked to.:
For your excel file, add a comn between A & B, call it offsets, place a value of 0 in all the cells of that column, save it as a comma delimited file, import per the help instructions.
Message 8 of 10
in reply to: Jeff_M
i try that but it always saying 'it cant read d point'
Message 9 of 10
Jeff_M
Using your sample xls file, I performed these tasks in Excel:
Changed the station column title to #station (this tells C3D that this is a comment line)
Inserted a new column after #station, named it offset, added 0 to all cells in that column
used Search & Replace to remove the '+' symbols from the stations
Save As a comma delimited file.
I then found the newly saved file in Windows Explorer and changed the extension from csv to txt
In C3D I ran the CREATEPOINTIMPORTFROMFILE command and entered the appropriate response to the prompts:
Command: _AeccCreatePointImportFromFile
...browse for the file.
1. Station, Offset
2. Station, Offset, Elevation
3. Station, Offset, Rod reading, HI
4. Station, Offset, Description
5. Station, Offset, Elevation, Description
6. Station, Offset, Rod reading, HI, Description
Enter file format (1/2/3/4/5/6): <0>: 5
1. Space
2. Comma
Enter a delimiter (1/2): <0>: 2
Enter an invalid indicator for Elevation <-99999>:
Enter an invalid indicator for Station Offset <-99999>:
Select alignment:
And the points were created.
Message 10 of 10
in reply to: Jeff_M
WAAAAOOOOOOOOOOOOH THAT IS AWESOME. IT WORKS LIKE A MAGIC. THANKS GOS BLESS
U RICHLY
Rail Community
