I have a special ditch profile that I'd like to use a linetype with arrows on. Currently, it shows the arrows going up station with my mainline profile. i.e. now water does flow uphill...
How can I flip this line?
Solved by jmayo-EE. Go to Solution.
Without seeing any images/files, create a linetype with the symbol/text flipped. Make a new profile style using the flipped line.
John Mayo
Not real sure if this will work for you with your profile, but we use a small lisp routine to reverse polylines, may work for you. Youll have to appload this then type "RPL"
See attached:
reverse the alignment the profile is associated with. This is found int the alignment toolsl.
