Hey everyone,
How I have come to this question is through the process of trying to realistically show a hydrant in profile view. First off it it possible to create a completely vertical pipe in C3D? Also if you can, is it possible to show that in profile view? Basically, what I am trying to avoid is representing a fire hydrant pipe by creating some sort of custom cyclinder part in partbuilder. I have done this, but do not like the results...any thoughts or suggestions?
Thanks in advance,
Stu
Not sure about the vertical pipes but the way we work around the hydrant display in Profile is to use a manhole with the correct diameter to represent the pipe (no sump and floor thickness of 0.001). We then use a label to insert a hydrant block at the top of the manhole.
There may be an option in pressure pipes that will allow you to do this but I haven't had any experience with it.
Mark Green
Working on Civil 3D in Canada
