I am working on a project which has numerous existing conduits laid out on the site. The location of the services has be picked up by a surveyor on the surface at numerous location and provided as a 2D polyline. The lines are quite long with a large number of nodes.
I wanted to represent the conduits as say a 100mm pipe and locate it about 0.6m below the surface to get an idea of how it impacts my works.
I tried converting it to a network fails as there is >70 nodes. I really only need to see the conduit on the cross section as I will definately avoid it.
Is there a way to display 3D polylines in cross sections?
Solved by sboon. Go to Solution.
There is a tutorial in the help system which explains how to project objects onto multiple section views.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
